removing side mirror and inside door handle trims.
Old May 17, 2007 | 07:21 PM
johnstef's Avatar
Default removing side mirror and inside door handle trims.
Okay i need to remove the driver side mirror. does it jst pop off? and then the inside dorr handle trims(ones that wear off easily). Do those just pop off also?
Old May 17, 2007 | 08:34 PM
auditech79's Avatar
Default RE: removing side mirror and inside door handle trims.
The mirror is bolted to the window frame so removing it would intail removing the door panel and popping off the plastic triangle trim.
The door handle trimdoesn't come off seperate from the door panel un-less you have a B6 cabrio.
Old May 18, 2007 | 02:22 AM
johnstef's Avatar
just did this and the trim is alot harder to get otu then u think!!!!!also putting back the panel is a BAITCH....
twinturbosixer
Jun 4, 2009 06:32 AM
mblayton
Jun 1, 2009 06:41 PM
WishIWasRWD
May 11, 2008 02:37 AM
moeron7
Apr 4, 2007 07:18 PM
pavs
Oct 27, 2006 11:01 AM
