Repeated Limp Mode
Old Jun 6, 2007 | 07:44 AM
dafrazi's Avatar
Default RE: Repeated Limp Mode
What is your max boost? Is it more than 20 lbs.? It shouldn't be.
Old Jun 6, 2007 | 12:28 PM
onepoint8tee's Avatar
You dont need a dealer or vag comto read fault codes and turn off CEL's. Autozone does that for free, as does many other shops that wont charge you an arm and a leg. You could buy a $30 code reader/clearer and do the same thing. If it goes into limp when youre pushing it in high rpms, its probably overboost. Try an N75 H valve. I switched back to the stock N75 recently and now I am going into limp mode when i push it too much in higher rpms. Too bad I broke the H valve when taking it out [:@]. I dont see how too stiff of a spring in the DV could cause overboost or anything that would cause limp mode.
Old Jun 6, 2007 | 03:11 PM
fenderstrat1184's Avatar
cant change the spring in the dv (its a hyperboost)
i'm not getting limp mode in the high rpms more like the midrange
i'm not boosting over 20lbs
looks like imma go try and find an autozone...
Old Jun 6, 2007 | 08:55 PM
dafrazi's Avatar
If you get a code for a bad N75 valve make sure you check the connection first. It's pretty common for the wires on the connector to break underneath the rubber boot. Mine broke. I soldered it back together and they broke again.I just got a new connector and need to solder it in.
NOMIND
Nov 29, 2017 12:29 PM
BrandonMarlowe
Jul 21, 2014 11:11 PM
NOMIND
Jul 21, 2009 11:49 AM
x1n54n3x
May 15, 2009 04:53 PM
auditt225
Mar 27, 2007 03:32 PM
