Replace engine bearings need help
Old Dec 8, 2007 | 01:38 PM
quattroforte's Avatar
Default Replace engine bearings need help
My b5 1.8t was knocking, so I removed the engine and took the oil pan off. #2 and #4 rod bearings are shot.I took them off and it looks like shaved metal and bubbled?. (I will post pics.) Now what I need to know is how to change them (and main bearings too, might as well) Do need to use a plastiguage(if thats the word?) or just put them on and torque them down. Could the crank be damaged from this?(It still looks smooth and shiny)
Old Dec 8, 2007 | 01:48 PM
auditech79's Avatar
Default RE: Replace engine bearings need help
Have the crank measured for wear at a machine shop, they can grind it down if need be.
Don't use plastigauge, buy a Bentley manual to get all the correct specs for the job.
Old Dec 8, 2007 | 02:23 PM
For the bently manual specs, is there anything special I need? Is the process simple or complicated (I don't have an extra $80 for a bentley)
also, I don't think there are anyshops around here that could check it, could it go bad again if I didn't have it checked?
badinstincts
Sep 7, 2011 04:03 PM
vangb2
Jul 24, 2010 12:16 PM
chancebuttars
Jan 1, 2010 03:42 PM
ammarj
Jan 22, 2008 07:28 PM
