replace wastegate
It is fairly simple if you are mechanically inclined. Basically you just have to remove the airbox, inlet pipe, exhaust manifold, loosen the cat bolts, undo a couple of oil/coolant lines and you are there. Takes about an hour to get off taking your time.
