Replacement Battery
Old Apr 10, 2005 | 12:57 PM
duganc's Avatar
Default Replacement Battery
I went to PepBoys and picked up a Bosch 48-700 and went to install it, but it is substantially smaller than the OEM. It just doesn't seem right. Has anyone replaced their battery with one of these?
Old Apr 10, 2005 | 01:50 PM
Shaunp05's Avatar
Default RE: Replacement Battery
Is this wat there called for in the Book ?
Is it small n the sense that the battary hold down wont
hold down ?
Make sure the CCA is the same as OEM
Old Apr 10, 2005 | 02:39 PM
CRAZYHAWK's Avatar
Have PepBoys install it.
Old Apr 10, 2005 | 02:54 PM
audiboy1618's Avatar
just make your on bracket of some sort.
Old Apr 10, 2005 | 10:48 PM
duganc's Avatar
Per the spec sheet it is the replacement but it is a good 2" shorter. It is the same height and depth. Just want to know if anyone else had the same experience and if everything was OK.
Old Apr 10, 2005 | 11:15 PM
david9999's Avatar
I got a pep boys and it was the same size. Something is not correct.
rdltmc3
Dec 30, 2024 11:54 AM
SuitedxACES
B7 Models
11
Dec 12, 2010 06:22 PM
eugenious
Oct 5, 2007 08:11 PM
ironman
Apr 30, 2007 06:37 PM
morrilld
Aug 20, 2006 01:38 PM
