Reving the A4?
Old Jun 7, 2006 | 11:08 AM
a4sport's Avatar
Default Reving the A4?
When I had my A4 out the other day, after I though I had all the problems fixed, it seemed to rev up really slow and same with the revs coming back down. I'd rev it to like 5 maybe and it seemed like it took forever to get there and come all the way back to normal idle.
Is this normal for the A4. It's B6 1.8T.
Old Jun 7, 2006 | 11:27 AM
acetrebo's Avatar
Default RE: Reving the A4?
While driving or while in neutral?
What was wrong before that you fixed?
Try to give some more detail and we'll try to help.
Old Jun 7, 2006 | 11:33 AM
a4sport's Avatar
In neutral. No dmg to the engine. Just some front end dmg like rad support, rad, fan shroud, ac condensor. Nothing internal to engine or anything. 5spd also.
Old Jun 7, 2006 | 01:58 PM
onepoint8tee's Avatar
When the fan or ac is going it puts lag on the engine and will do exactly what you are saying is happening. Especially in hot weather since your fan will be coming on a lot.
Old Jun 7, 2006 | 02:38 PM
hoonee46's Avatar
Had a similar problem, cept i had a clogged EGR and cat... Cleaning out EGR helped both ways, revving up and coming down... headerback should get the car to normal.. better than normal...
Old Jun 7, 2006 | 10:04 PM
StepUpProductions's Avatar
mine seems to do the same thing, not so much getting there but it seems to take a long time coming back down, im pretty sure its normal... if its going slow getting up there id definatly check it out
WADZ000
Jan 25, 2009 01:21 PM
vwroyd
Jun 8, 2008 12:10 AM
thareals4
Jun 4, 2008 12:50 AM
thareals4
May 18, 2008 04:26 PM
fitz01
May 16, 2006 01:28 PM
