Revo
Old Jan 26, 2005 | 03:09 PM
brrman's Avatar
Default RE: Revo
I gave you the links so that you could go there and read it for yourself.
Old Jan 26, 2005 | 04:03 PM
dfera's Avatar
Default RE: Revo
Ok thanks didn’t see it earlier, I am work and I don’t have my IE window open all the way.
Old Jan 26, 2005 | 09:31 PM
turbo's Avatar
Default RE: Revo
I went with the sps3 only because it had the most controles on it and things like the timing I will not use now but may need it later depending on what mods I do later.
also on the back side of the controler there is a chart that will show where setings can be set for all options.
It also has a booklet that shows where timing can be set with diferent oct gass/race fule.
I would not advance timing past 3' on pump fule.
I am not sure of cost from sps2 to sps3 but if it is not that much more for the sps3 you might as well get it.
I paid $325 for the sps3.
The forged DV is a must because the stock one is plastick and tends to fail at a high boost.
Lastley I suggest you get a high performance air filter to (k&n,green) but it is up to you.
Old Jan 26, 2005 | 10:16 PM
audiboy1618's Avatar
Default RE: Revo
yeah, if your gona go with revo def go sps-3. I like how they have the differnet settings.
Old Jan 26, 2005 | 11:02 PM
dfera's Avatar
Default RE: Revo
Thanks guys
Donman19
Dec 14, 2011 11:45 AM
masteroc
Sep 11, 2007 09:21 AM
Jestnomen
Apr 10, 2006 08:52 PM
eipracing
May 11, 2005 10:26 PM
justgotanaudi
May 2, 2005 11:55 PM
