rim problems
Old Aug 29, 2007 | 04:55 PM
supahaze's Avatar
Default rim problems
[hr][hr]i got 18" ARE HAZE rims but i had lots of problems installing them for my front 2 because of the calipers so i got 10mm hubcentric spacers for the car custom made but they're still off by a couple mms so they move a little which still gives me a rougher ride and over 60mph the wheel kinda shakes now would getting a wheel alignment and or a high speed balancing help????
Old Aug 29, 2007 | 05:21 PM
akielb's Avatar
Default RE: rim problems
what is the center bore of your wheels - I have some rings from discount tire that they sent me and if they are the right size I'll give'em to ya
Inside dimension is 57.1mm this fits the hub on my audi and outer dimension is 73mm. your wheels inner bore would have to be 73mm for these to work - my wheels had a bore of 66mm.
And if you haven't had an alignment and balance done on the set - get it done
Old Aug 29, 2007 | 05:47 PM
Adam@mvp's Avatar
You also might need a spacer, but then again usually you make sure that the wheels, offset etc clear your calipers before you purchase them.
Adam~
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
