route for the power wires?
Old Jul 20, 2007 | 04:13 PM
flake's Avatar
Default route for the power wires?
I need help figuring out where to route the power wires and other wires for stereo install. I need to run back to the trunk.
If anybody knows an easy way to do this please post. I don't really know what pieces come off the best
Old Jul 20, 2007 | 04:16 PM
Lazer Viking's Avatar
Default RE: route for the power wires?
STFA !
Old Jul 20, 2007 | 05:25 PM
MrFlippant's Avatar
If you're not already comfortable figuring out how to run cables on your own, then I would highly recommend leaving the installation to trained professionals.
Old Jul 20, 2007 | 05:32 PM
DENIS415's Avatar
power wire will run down the passenger side of the car, you RCA wire will run on the drivers side of the car.
Old Jul 20, 2007 | 08:45 PM
a88fl1's Avatar
just follow the wire already in the car, there should be room
Old Jul 20, 2007 | 08:51 PM
flake's Avatar
Also those 2 rubber gromets by the battery are they to be cut out or do they twist out or what?? Do I need to take the back seat out to get it through to the trunk?
Old Jul 20, 2007 | 08:55 PM
a88fl1's Avatar
Take it out and see, im guessing yes.
Old Jul 21, 2007 | 01:15 AM
qUaTtRoA4's Avatar
Alright...da way I did it was running from da battery through the grommet behind da ecu and down da drivers side
heres a PICTURE of da grommet (in da engine bay) behind da ecu
And here's a PICTURE of the backside of da grommet (under da dash)
the way I got my power wire through the grommet was by first, starting under da dash and slicing a hole in it wth my leatheman (any knife that you have a good handle on)...then I straightened out a wire coat hanger and duct taped it to da wire (spiral taping so dat it's tapered at the end thats penetrating the grommet)...now pull on the coat hanger and pull the wire through and run it to da trunk....
this will be way easier if you remove the ECU box...though I did not
good luck!...hopefully something I said will help you out
McGovs2.7TB5
May 4, 2008 08:41 PM
v8smkr
Mar 10, 2006 04:35 PM
VB05
Nov 15, 2005 02:24 PM
AUDI12345
Oct 25, 2005 01:28 AM
brogenville
Jan 4, 2005 06:42 PM
