Short shirter self install?
Old Jul 23, 2005 | 11:52 PM
VB05's Avatar
Default Short shirter self install?
Would it be overly difficult for me to self install a short shifter to save some money? I have no idea how the install goes but im sure there would be directions (question is how clear the directions are). I have a 98 2.8 by the way. And what brand do you recommend b&m, neuspeed, etc...
Old Jul 24, 2005 | 12:29 AM
apg96's Avatar
Default RE: Short shirter self install?
i have been trying to do mine for the last week. With a 98 (pre 99.5) u need to remove the center console. I can give u how to do this, i did it today and it took me like 30 mins. Its a few plugs and some wires to inplug. Then the shifter install is just some bolts but before u do anything makesure u have exactly what u need. (tool list on the insturctions). Its alot of simple stuff, but my first snag was teh center console removal and i did that today and i got to a bolt (the last one before to get out the sifter) an di stripped the last bolt. So i need to gte that taken out. Im having this done on monday and then i will finish everything up **knock on wood** on tuesday. Ill post a full review of the shifter (b&M) and of putting it in.
Old Jul 24, 2005 | 12:43 AM
VB05's Avatar
alright, thanks alot man.
Old Jul 24, 2005 | 02:50 AM
trailboss's Avatar
It can be done with out removing the center console on earlier models, but if you want things wide open then your best bet is to remove it.
Old Jul 24, 2005 | 03:17 AM
Yuikio's Avatar
it usually is about a 2hour install, there are two nuts that are hiding under the console that you may or may not be able to reach...but to get to that stage is really easy; unscrew shift ****, pull off the shift boot, two screws to get the sound insulation pad out (I think they're 10mm and 13mm) and then the time consuming part. Definitely try it yourself first.
Pbcrazy
Oct 8, 2012 08:19 PM
rxphiler
Mar 22, 2008 10:25 AM
kolan67
Oct 13, 2007 07:21 PM
Gutterpelican
Sep 13, 2006 05:34 AM
headshok2002
Jan 29, 2006 05:49 PM
