Side Airbag
Old Oct 15, 2007 | 05:02 PM
audrageous's Avatar
Default Side Airbag
Hello to All,
New member here and am I glad I found this site! I've done some searches and looked around and can't find the info I'm looking for so thought I'd ask.
I need to access the connection to the side airbag on the driver front seat. How do you remove the panel on the back of the seat?
TIA, Jim
Old Oct 15, 2007 | 05:11 PM
auditech79's Avatar
Default RE: Side Airbag
It depends on what model you have, B5 or B6? You would have to remove the seat to gain access to the wiring, or at least tilt the seat backwards. All the wiring comes up through the floor, the connector in yellow is the air bag.
Old Oct 15, 2007 | 08:22 PM
audrageous's Avatar
Thanks tech79.
It's a B5, the seat needs to be removed to access? I just need to check the connection.
Regards,
Jim
Old Oct 15, 2007 | 08:24 PM
auditech79's Avatar
Yeah un-bolt the seat and tilt it backwards, you should see the harness coming up through the floor.
Old Oct 22, 2007 | 02:21 PM
audrageous's Avatar
where can i find cable and software to check codes on a 1998 A4 Quattro 1.8T ?
i think it's a B5, correct?
airbag light is on, not sure which airbag or why. i was told tech bulletin suggest using dielectric grease on connector for side airbags (yellow connector under seats), been there done that, light is still on.
Old Oct 22, 2007 | 02:26 PM
audrageous's Avatar
Default audi certified repair shop in san mateo ca
can anybody suggest one?
craigcjam
Feb 9, 2014 06:04 AM
M3Armand
Mar 30, 2013 09:40 AM
vtraudt
Oct 25, 2010 02:46 PM
vserghi
Jun 22, 2009 07:33 AM
crega001
Jun 14, 2006 08:28 PM
