side mirror removal
Old Oct 5, 2007 | 11:07 AM
micah's Avatar
Default side mirror removal
To remove the side mirrors, do I simply remove the door panels to loosen the bolts for the mirror housing? And yes, I am removing the whole mirror assembly. Thanks!
Old Oct 5, 2007 | 11:14 AM
techbod's Avatar
Default RE: side mirror removal
[IMG]local://upfiles/12092/75CE639CD82143AF857DC349841AE639.jpg[/IMG]
Old Oct 5, 2007 | 11:17 AM
micah's Avatar
so to get to the #4 bolt, I would have to remove the whole door panel or is there a way to remove just the triangular shaped trim piece without removing the door panel?
Old Oct 5, 2007 | 12:59 PM
99A4NOW's Avatar
I don't exactly remember but you should be able to remove the bolts by just popping off the triangle trim piece on the inside. The part I'm not really sure is if the door panel needs to be removed in order to unplug the wire harness.
Something I've been wondering (sorry for the hi-jack) but when I pulled my mirror off the other day I noticed there was wiring for both the defroster and the dimming sensor. My mirror actually had the connections for the defroster, but they weren't hooked up. Anyone have any insight on this?
Old Oct 5, 2007 | 01:00 PM
auditech79's Avatar
You would have to remove the door panel to get the triangle piece out. Now depending on what year A4 you have (which you didn't post BTW) the door panel can be harder or easier to remove.
Old Oct 5, 2007 | 01:27 PM
auditurbo381's Avatar
auditech....what about on a b6. hard? my right mirror got ripped off my a motorhome [:-]
Old Oct 5, 2007 | 01:34 PM
micah's Avatar
sorry...2000 2.8Q...Is it just the two screws on the sides of the panel to remove it?
Old Oct 5, 2007 | 01:42 PM
micah's Avatar
nm....found this if anybody else was wondering
http://www.audiworld.com/tech/int49.shtml
Old Oct 5, 2007 | 02:05 PM
auditech79's Avatar
Yeah you have those two screws at the top, then you have to remove the little cover on the bottom of the handle (should be a small screw holding that on) then there is two more small screws behind the lower handle cover. Once the bolts are out, pull the panel stright up.
As for the B6 question there are several bolts, you have to pop off the wood trim (or aluminum) and there should be 4 screws back there, pop off the trim under the door handle, two there, then one at the very bottom of the panel. On the B6 the panel doesn't pull straight up, its snapped on with several clips, what i do is grab a hold of the bottom of the panel and give it a real good yank. You might have to replace a few broken clips if you like, it really doesn't matter.
jaimek
Feb 21, 2015 07:19 PM
phelps69
Apr 23, 2012 05:22 PM
Flrnorman
Apr 21, 2009 03:42 PM
Trey25
Sep 14, 2007 03:35 AM
