So i found out how to run unlimited boost...
the way i have it now, is it is plugged in electrically, its sitting in the TIP cause i dont want a hole, and the other 2 nipples on the n75 just have a hose going between eachother, so the n75 is basically just jerkin itself off
i figured he'd see this thread next time he comes on
i tried taking the n75 out of the TIP and put a bolt and clamp to plug the hole but it still wont work, everything seems to check out but i still can't get it to go past 5 psi. think the boost controller is broken? i had to soder the electrical connection between the controller unit and the control motor. should i check to see if its receiving power?
I can't be of much technical help in this state, but maybe this will cheer you up:
https://www.audiforums.com/m_744306/tm.htm
scroll down for the pics.
reason why it wouldn't work is cause the ebc's step motor isn't working properly. so i hooked my n75 back up to the banjo bolt and wg but left the profec b still in my car and splitting the vacuum line between the fpr and intake mani cause i didn't think it would make a difference. i drove my car and now its holding 20psi and spiking 22-23 psi, it used to hold 16psi and spike 18-19psi.
the whole reason i got the ebc was to hold 20psi, but it didn't work, so i hooked my car back up the way it was originally, and now im holding 20psi...crazy[&:]
