Sound system
Old Nov 9, 2005 | 03:16 AM
onepoint8tee's Avatar
Default Sound system
I have a 2000 with the symphony system. It has 4 speakers up front ( including tweeters) and two on the back deck. From what I read, there is a Bose system with amps on each speaker, and also has speakers in the back doors. I also understand that there is a version of the Symphony radio with speakers in the back doors also. My rear deck speackers look like they have a small amp on the bottom of the speaker in the trunk. Im trying to figure out what size my front speakers are, and if they have amps on them. I have read 4 inches, and then 5.25 inches. Does anyone know, for my setup, what size the front speakers are? Jst trying to get an answer before I go taking the door panels off. Also, I believe the front door speakers are component woofers, because of the tweeters on top. If I put in a speaker which has a tweeter on it already, will it sound crappy? THANKS.
Old Nov 9, 2005 | 04:11 AM
miked's Avatar
Default RE: Sound system
On cartoys.com if you put your car make/model/year etc it will tell you the speaker sizes as well as deck sizes. Tells you if its direct fit, if it works with a fit kit, or needs custom install. Hope that helps.
Old Nov 9, 2005 | 10:25 PM
ckandes1's Avatar
ORIGINAL: miked
well that was just way too easy.
Old Nov 10, 2005 | 12:25 AM
rjplunk9's Avatar
same wtih bestbuy.com and circuitcity.com
Old Nov 10, 2005 | 12:45 AM
BFlan2001's Avatar
if you've got amps connected to your rear deck speakers then you have the standard, non-bose system. your front door speakers are 4", they are not component speakers.
copter47
Jun 4, 2011 06:48 AM
reedy_boii
May 6, 2011 09:04 AM
khj677turbo
Feb 6, 2007 01:04 AM
crispycream13
Nov 21, 2006 01:13 AM
macumberc
Dec 6, 2005 11:21 PM
