sound system ?'s
Old Nov 21, 2006 | 12:15 AM
  #21
silver_bullet's Avatar
Default RE: sound system ?'s
I'd go with a pair of 10's or 12's. I've got 2 12's plus 2 1000w amps and still have plenty of space in the trunk. Depending on how much bump you want, pick your watts. I bet 400 would be decent if you're not in need of too much thump; don't let somebody tell you you won't hear anything because of "dampening" just to get you to spend more cash. Used components aren't a bad way to go either as long as they weren't thrashed. Good luck.
Old Nov 21, 2006 | 12:24 AM
  #22
Worlddre's Avatar
ORIGINAL: silver_bullet
as i previously stated power will not dictate how much output one will get out of any particualr set up
Old Nov 21, 2006 | 12:27 AM
  #23
It will play a factor. There's a reason a 2000w set up costs more than a 200w set up, and it isn't because the amps look nicer. Sure other factors play a role, and you have to be wary of how companies rate their components, but wattage is a factor.
Old Nov 21, 2006 | 12:32 AM
  #24
Worlddre's Avatar
i didnt say it would be a factor i said it would not dictate the amount of output you get. large amounts of power are not required to get decent output from a low frequency system.
Old Nov 21, 2006 | 12:35 AM
  #25
Okay, Worlddre, we're in agreement!
Old Nov 21, 2006 | 01:13 AM
  #26
Worlddre's Avatar
copter47
Jun 4, 2011 06:48 AM
reedy_boii
May 6, 2011 09:04 AM
MyCrazyCar
Jul 29, 2008 04:47 PM
khj677turbo
Feb 6, 2007 01:04 AM
macumberc
Dec 6, 2005 11:21 PM
