Spark Plug Gap with SpeedTuning Chip
Old Dec 22, 2007 | 02:15 PM
feerocknok's Avatar
Default Spark Plug Gap with SpeedTuning Chip
Just put new plugs in a week ago, BKR6Es gapped to .032". After that I realized the 23rd was coming, so I sent out my ECU to SpeedTuning. Just got it installed last night (got a bit of other work done as well: airbox, k&n, forge 007, boost gauge, rear fog light mod, diy short shifter), and it's pulling pretty good, as long as I'm not going over 5500 RPMs.
I've read 293709715409 times to narrow the plug gap on a chipped car, but I was curious if that was my 5500 RPM issue?
Old Dec 22, 2007 | 03:05 PM
cincyTT's Avatar
I'm make believe
Default RE: Spark Plug Gap with SpeedTuning Chip
you need to gap them to .028. That is your plugs getting blown out at 5500rpms.
Old Dec 22, 2007 | 03:51 PM
feerocknok's Avatar
Thank you, thank you, thank you!
Old Dec 22, 2007 | 03:58 PM
auditurbo381's Avatar
cincy? should i run this gap on my b6 as well....my ecu if off in a fedex box somehwere. just curious when i get it back what gap i need
Old Dec 22, 2007 | 04:06 PM
recommendation for plugs are welcomed as well. how do i know what gap they are? is it in the model of plug. please help
Old Dec 22, 2007 | 04:23 PM
cincyTT's Avatar
I'm make believe
All 1.8ts should run the same gaps.
Spark Plugs
OE Plugs: NGK PFR6Q - .032" gap
For Stock Cars - .032" gap:
[ul][*]NGK BKR6E[*]Autolite 3923[*]Denso Iridium IK20[/ul]
For Chiped Cars - .028" gap:
[ul][*]NGK BKR7E[*]Autolite 3922[*]Denso Iridium IK22[*][/ul]
I prefer the ngk bkr6's and have used the autolites also, work fine aswell. Just get copper plugs and change them every 15-20k miles.
Old Dec 22, 2007 | 09:08 PM
thank you. thank you
Pilipenko
Nov 28, 2011 10:06 AM
ee99ee
Oct 12, 2011 12:28 PM
s_sawyer759
Oct 12, 2010 10:46 PM
bluesnapper
Aug 11, 2009 08:43 PM
george3.3
Oct 29, 2008 11:19 AM
