sppedtuning ------ wont start
Old Dec 31, 2007 | 06:01 PM
auditurbo381's Avatar
Default sppedtuning ------ wont start
got my ecu back form speedtuning and my car wont turn over. i have just flushed the coolant. and i just put the sensor back in. tried to turn over. nothing, no fire. i went to check the fuel bar and bleed it. no fuel came out. the car was low on gas. but was running ( o mi to empy) i put 5gallons of 91 in and still wont start. HELP
Old Dec 31, 2007 | 06:14 PM
Bogie's Avatar
Default RE: sppedtuning ------ wont start
Is the ECU plugged in completely with the tabs pushed back in? If the ECU is installed right, then it's probably your battery...will the lights come on?
the ecu is plugged and clipped yes. the car is turning over. but no fire
Old Dec 31, 2007 | 06:30 PM
sineo's Avatar
Could be something to do with the ECT sensor. I'd check it again.
Old Dec 31, 2007 | 07:45 PM
i just checked everything over for a third time. may i reiterate that there is no fuel im my fuelbar
Old Dec 31, 2007 | 08:08 PM
ImTheDevil's Avatar
Possible fuel pump failure then - when you turn the key on for full electrical power, the fuel pump should kick on to pressurize the rail and prep the engine for starting.
Old Dec 31, 2007 | 08:46 PM
Audi_Skydiver's Avatar
Check your fuel pump fuse, number 27 I think, and see if it is blown if it is replace it and see if it solves your problem.
josh
Old Dec 31, 2007 | 09:59 PM
apr_a4's Avatar
its not in ur sig
Old Dec 31, 2007 | 10:15 PM
ORIGINAL: apr_a4
its not in ur sig
Huh?
Josh
Old Jan 1, 2008 | 01:16 AM
apr_a4's Avatar
ORIGINAL: ThePaintballGuy
ORIGINAL: apr_a4
its not in ur sig
Huh?
Josh
he didnt put speeedtuning chip in his sig and now its like man im not gona start lol
