sppedtuning ------ wont start
Old Jan 7, 2008 | 11:26 AM
auditurbo381's Avatar
Default RE: sppedtuning ------ wont start
fixxxed. thanks. fuse is fine...any other ideas
Old Jan 7, 2008 | 12:31 PM
AUDI05's Avatar
ORIGINAL: auditurbo381
fixed what? Is it running now?
Old Jan 7, 2008 | 12:38 PM
A4speed's Avatar
fixed as in speedtuning is now in his sig, i think thats what he means.
Old Jan 7, 2008 | 12:45 PM
sineo's Avatar
Well, have you done any troubleshooting regarding the fuel pump itself?
Old Jan 7, 2008 | 12:54 PM
feerocknok's Avatar
Didn't read anyone suggest this and am in shock:
Turn the key to the on position. Leave it there for three minutes. Start the car.
Throttle body alignment.
Old Jan 7, 2008 | 12:58 PM
CLX's Avatar
CLX
Zombie Defense Force
TB alignment won't have anything to do with no fuel getting to the rail.
Old Jan 7, 2008 | 01:07 PM
feerocknok's Avatar
Hmm, true on that. Doesn't sound like it was done though, so should prob still be kept in mind.
Old Jan 7, 2008 | 01:31 PM
  #18
d3m0nz3y3's Avatar
got my ecu back form speedtuning and my car wont turn over. i have just flushed the coolant. and i just put the sensor back in. tried to turn over. nothing, no fire. i went to check the fuel bar and bleed it. no fuel came out. the car was low on gas. but was running ( o mi to empy) i put 5gallons of 91 in and still wont start. HELP
might not be an ECU related problem, but you should check to make sure that none of the pins in the ECU are bent or broken...
--d3
Old Jan 7, 2008 | 02:39 PM
  #19
A4speed's Avatar
go borrow a code reader from autozone, who knows if you have any codes thrown?
Old Jan 7, 2008 | 02:51 PM
  #20
i have an obd II ...when i plug it in and try and pull codes it says link error.... i unplugged it and tried it in another vehicle it works fine. so...take that into considersation. i will try and do the TBA adjustment. i checked the pins in the ECU, they are all fine. still no fire.... and no fuel. i will try the TBA after work
