sppedtuning ------ wont start
Ok first of all I am not new to german cars, I used to be a regional sales manager at Dinan Engineering (BMW Tuner)
Second, I just had an ignition coil fail and the car would not start!! It was towed to the dealer under the Audi roadside assistance program. The Diagnosis was nothing fuel related, only ignition coil.
Did you try quickly disconnecting the hose to the intake mani and spraying ethanol/starting fluid in there (then putting the intake hose back on quickly) and see if it will fire or start? If so,it isprobablya fuel supply problem. If the fuse is ok, then check: current/voltage to the pump, relay...anddon't disregard a clogged up fuel filter. Itdoesn'thappen oftenonour B5 A4s(from my experience), but maybe you filled up with a dirty tank of gas.
Hint:Avoid filling up agas station if you see the tanker therefilling thetanks that day. Although "filtered" that gasoline will becleaner the next daywhen particles get a chance to settle after being stirred up from filling the underground tanks.
ORIGINAL: auditurbo381
yah out of gas would solve my problem now wouldnt it lol. auditech....how do i diagnose at the relay
Use a bentley manual to find the relay, it should be in the relaypack under the steering wheel.
kinnes042
S4
Apr 10, 2013 06:29 PM
Billydakid
Oct 29, 2010 02:40 AM
brit.mike13
Oct 17, 2010 08:26 PM
