squeak
Old Jun 9, 2006 | 09:01 PM
impaler2383's Avatar
Default squeak
Alright, the squeaking i'm getting is def not the brakes. I got into the habbit of letting down the windows now and I've noticed this squeak every time I hit bumps in the road. It's not like it'll happen sometimes and others not....every time. Does it just mean connections should be oiled? Does a shock squeak when it goes bad? Any ideas?
Old Jun 9, 2006 | 09:49 PM
Trey25's Avatar
Default RE: squeak
haha welcome to the club, my L/F is the same. Most likely its a control arm, get under there and check it out. Look for oil on the shock itself and push down on the car to see if it bounces excessively. Shocks do squeek when they go bad but its not a common thing on audis, control arms are, how many miles are on the car? Oh and you can't grease the control arms on an audi[:@]. Well the upper can but you'de have drill and fit a nipple. Just replace them.
Old Jun 10, 2006 | 08:47 PM
david9999's Avatar
Default RE: squeak
Control arm bushings are wearing out. Common problem
Old Jun 15, 2006 | 03:36 AM
Default RE: squeak
58000 miles....how much would bushings run? time to install? sigh, just as I was saving up for an exhaust
no oil leak btw
Old Jun 15, 2006 | 03:52 AM
wood_e's Avatar
Default RE: squeak
Mine has a squeak in the rear end on the drivers side. It happens when going over bumps... could be an end link?
Old Jun 20, 2006 | 12:10 AM
Default RE: squeak
Quick question, could there be another reason for the squeak? The steering is very tight still. could the door hinge be loose causing the seals to rub and make noise? just speculating here. I'm still not convinced about the control arms or the bushings. mileage seems too low to me (58000)
Pjbrof
Aug 5, 2009 11:44 PM
ron86toy
Jun 4, 2009 05:14 PM
marcb0127t
Feb 7, 2009 07:55 PM
Mathis147
May 19, 2008 04:57 PM
Trey25
Jul 28, 2006 01:22 PM
