Starting issue
Old Jul 6, 2006 | 05:59 PM
kaklexicon's Avatar
Default Starting issue
Every morning (cold start) when i start my car up, it never starts the first time. But always the second. It used to be every once and a while, but now it's every morning. It starts up first try for the rest of the day though. It's just that initial morning startup. It turns and then just as the starter stops and the engine takes over it just sputters out. Try it again and it starts up like champ. I have a new starter in there so I know it's not the starter. So I need some help on what this could be.
Old Jul 6, 2006 | 07:35 PM
dafrazi's Avatar
Default RE: Starting issue
I had a similar problem on an Oldsmobile Aurora. It was a fuel pressure leak. No fuel was leaking...just the pressure would bleed off over night.
Old Jul 6, 2006 | 07:44 PM
wood_e's Avatar
Sometimes the fuel pump check valve can cause these issues. The system loses pressure over time when the valve doesn't work.
Old Jul 7, 2006 | 08:07 AM
david9999's Avatar
Agree.
Old Jul 7, 2006 | 11:59 AM
kaklexicon's Avatar
Hmm, ok. In terms of repair is this a minor fix or a major fix?
nelson0639
Dec 8, 2014 04:44 PM
a4fan2000
Jan 14, 2011 11:39 PM
Ghostrider II
Apr 9, 2010 01:03 PM
SPhilli911
May 7, 2009 03:30 PM
knyks342
May 24, 2008 01:16 AM
