steering sound question
Old Apr 11, 2005 | 06:00 PM
OWDI's Avatar
Default steering sound question
Hey guys,
I notice a sound once in a while when i am turning/steering my car (left or right). BTW i have 99 2.8 Q Tiptronic. anyway its like a "KISH" sound. Like if i have turned to far. Its sounds like gas (compresed air..not oil). Any ideas on what it could be? i know its hard if you havent heard it. Could it be tie rod ends? Just thought u guys know what it might be...
Old Apr 11, 2005 | 06:09 PM
Jestnomen's Avatar
6th Gear
Default RE: steering sound question
so it doesnt sound like the pump making noise?
Old Apr 11, 2005 | 06:44 PM
OWDI's Avatar
i dont know what you mean by the pump making noise...its weird the sound...only sometimes it happens...my steering fluid resevoir is over max, cause i filled it up too much about 2 months ago...i bought the fluid from audi, so i know its the correct one..but that noise is weird...cant really tell where it is comming from all i know is that when i turn all the way i get the sound...
Old Apr 11, 2005 | 08:30 PM
ImolaS4's Avatar
ORIGINAL: OWDI
That's why... you have too much steering fluid. Jest was on the right track with you. That kind of sound is the pump.
Try to remove some of the excess fluid. Other than that, don't worry too much about it.
Old Apr 12, 2005 | 01:09 AM
BFlan2001's Avatar
regardless of how much fluid is in your reservoir, if the steering wheel is fully turned in either direction you're going to hear the pump. it's not good for your car, you should avoid doing that if possible...
Old Apr 12, 2005 | 01:16 AM
ImolaS4's Avatar
ORIGINAL: bentframe
.... if the steering wheel is fully turned in either direction you're going to hear the pump. it's not good for your car, you should avoid doing that if possible...
Very true, too. Shaould have included that with my post. Thanks for clearing it up bent.
Old Apr 12, 2005 | 01:53 AM
BFlan2001's Avatar
Old Apr 12, 2005 | 05:07 PM
OWDI's Avatar
thanks guys...i KNOW you guys are right...ok...so i just buy a "basting tube thing they use for turkeys at thanksgiving" and suck the fluid out from the pump?
Old Apr 12, 2005 | 05:15 PM
BFlan2001's Avatar
correct, sir.
playboy00786
Apr 24, 2011 05:01 PM
eddy123
Jan 14, 2010 12:21 PM
hussain_asghar
Sep 3, 2009 10:00 AM
dragondesigns
Sep 29, 2006 08:43 PM
apg96
Apr 19, 2005 11:23 PM
