steering sound question
Hey guys,
I notice a sound once in a while when i am turning/steering my car (left or right). BTW i have 99 2.8 Q Tiptronic. anyway its like a "KISH" sound. Like if i have turned to far. Its sounds like gas (compresed air..not oil). Any ideas on what it could be? i know its hard if you havent heard it. Could it be tie rod ends? Just thought u guys know what it might be...
i dont know what you mean by the pump making noise...its weird the sound...only sometimes it happens...my steering fluid resevoir is over max, cause i filled it up too much about 2 months ago...i bought the fluid from audi, so i know its the correct one..but that noise is weird...cant really tell where it is comming from all i know is that when i turn all the way i get the sound...
ORIGINAL: OWDI
Try to remove some of the excess fluid. Other than that, don't worry too much about it.
regardless of how much fluid is in your reservoir, if the steering wheel is fully turned in either direction you're going to hear the pump. it's not good for your car, you should avoid doing that if possible...
ORIGINAL: bentframe
.... if the steering wheel is fully turned in either direction you're going to hear the pump. it's not good for your car, you should avoid doing that if possible...
