power door locks
Old Apr 12, 2005 | 04:14 PM
skidplatexa4's Avatar
Default power door locks
Ok so I know my car has it's little quirks but I'm trying to work all of them out. My newest one is when i lock the car with the key from the driver door it used to roll up the windows and lock all the other doors, and now when i lock it it only locks the driver door not the others like it used to. But when i unlock the car it works fine. What module or relay went bad and how would i fix this being it s getting annoying. I still love this car even though it has a mind of its own.
Old Apr 12, 2005 | 04:16 PM
Jestnomen's Avatar
6th Gear
Default RE: power door locks
Don't you have remotes? You can Vag the car to roll up the windows via the remote. I know this didn't answer your question though.
Old Apr 12, 2005 | 04:22 PM
I have remotes but they stopped working for some strange reason. I was doing research about this a while back and saw that the stock alarm system is junk. Also the alarm used to just go off for no reason. This car is wacky. Thanks jest
Old Apr 12, 2005 | 04:26 PM
Jestnomen's Avatar
6th Gear
I would try replacing the batteries in the remote, then reprogramming them. Maybe your remote locking module is dying. Yes, the stock alarm isn't all that great.
Old Apr 12, 2005 | 04:31 PM
Sounds good I just put new batteries in them and tried reprogramming them but was'nt to succesful do you have a write up on how to reprogram the remotes. If you do that would be great
Thanks Jest for the quick response
Old Apr 12, 2005 | 04:41 PM
Jestnomen's Avatar
6th Gear
Old Apr 12, 2005 | 04:44 PM
clconversion's Avatar
are you leaving your windows down when the alarm is going off buy its self ? if so there is a button on the drivers side pillar between the front and rear passenger area hit that button it is for thev motion detector
Old Apr 12, 2005 | 04:54 PM
Thanks jest i'll try that tonight. i tried it a while back and it did'nt work maybe i did it wrong or got the wrong info. To cl the alarm thing hasnt happened in a while it was a freak thing for like a week but it is still relevant to the door lock thing being the red led used to light when i locked the car but now it does not and does not lock with the key from the outside only if i hit the lock switch on the inside. but it unlocks fine.
Old Apr 12, 2005 | 05:49 PM
TGPorsche96's Avatar
if you have a new alram system it deactivates it sometimes. it did with mine atleast and three of my friends...
The Bishop
Feb 24, 2008 09:40 PM
rightsandlefts
Nov 20, 2007 06:52 PM
Henley
Aug 31, 2007 11:39 PM
Shaunp05
Mar 12, 2005 01:17 AM
