Still not fixed
Old Oct 11, 2007 | 01:04 PM
99AudiMN's Avatar
Default RE: Still not fixed
alright, so i havent torn the car down yet cause i first wanted to check to see if maybe i had air in the coolant system somewhere. Cuz when i refilled i only bled the front valve and didnt turn my heat on at all. so i crank the heat and slide the heater core hose the one with the little bledder hole off the pipe. i start the car and im getting no heat for a while (prob. cuz the car was cold). im seeing a bunch of air and bubbles coming out though. i also began to get heat goin,so i began to think i solved it. Wrong. i take it for a drive after hookin the hose back to the heater core pipeandthe temp.starts to get hot again. once back to the driveway, my heat goes cold again. i bled the air for about 20min or longer id say. the bigger coolant hose in front of the expansion tank was making a sucking noise and pulsating sounding like it was choking or somethin... it seemed my heat would only get hot if i squezzed the hose and got coolant flowing or somethin.imgettin frusturated of this car overheating... so do i tear down and check thermostat and change water pump or am i missing something...
Old Oct 11, 2007 | 01:29 PM
hiwords's Avatar
that squeezing the coolant hose sounds fishy. see if there's sumthing blocking it. also, check the expansion tank in that area. also b4 taking things apart, check if the temperature is normal. and ur saying ur see alot of bubles coming out of the bleeder hole by the firewall? run ur car with the rad cap off and see wut happens. u kno another thing u gotta do is talk to ur car nicely and kiss it good night evry night cuz i think it's mad at u right now lol.
Old Oct 11, 2007 | 01:45 PM
acetrebo's Avatar
proper bleed procedure:
pull hose back from heater core to expose hole.
remove three screws holding down expansion tank.
remove cap from expansion tank, and lift it up so its higher than the exposed hole.
fill tank with coolant until coolant is coming out of the exposed hole on the heater core.
replace expansion tank, replace hose on the heater core.
start car, fill coolant to proper level on tank. Run car, see if level is correct.
Still sounds like you have either a blocked heater core, or closed thermo. Try the bleed precedure and see it that helps.
Dave, did you mean 98 degrees celcius, rather than F? 98F doesnt seem very warm for the thermo to open.
Old Oct 12, 2007 | 01:08 AM
99AudiMN's Avatar
ok ill try the bleed thing again. otherwise ill take it apart tomarrow morn. and test the thermostat. i just put a therometer in the pan right and watch for it to open? im gonna replace the pump too anyway just because. and maybe i should talk nice to it cuz its been hearin nothin but cuss words for the last 4 days....
Old Oct 12, 2007 | 03:49 AM
techbod's Avatar
98Cbut just checked my database and the 1.8t 2000 model opens at 87C, and when bleeding the system ensure the temp setting in the cabin is on hot other wise you wont bleed the heater matrix
Old Oct 12, 2007 | 07:30 PM
99AudiMN's Avatar
well, i did it this time, i stripped the bolt on the bottom part of the fan pulley, and just snapped the timeing belt tensioner bolt trying to compress the the tensioner....i quit
Old Oct 12, 2007 | 07:34 PM
auditech79's Avatar
Your not supposed to turn any bolts when collapsing the tensioner, you're supposed to use an 8mm allan socket to turn the eccentric pulley over, not the bolt that holds it on.
As for the bolt on the bottom of the fan pulley, its an allan right? Use a torx socket (6point) thats a little bigger than the allan you were using and bang it in with a hammer and break it loose by hand.
Old Oct 14, 2007 | 12:31 AM
  #18
99AudiMN's Avatar
well thankfully i got the timing belt tensioner bolt out of the block. i have the other bolt from the old tensioner to use. and i did use a torx bit on the fan pulley bolt and it just spun n stripped out on me. i tested the thermostat it opened when it should so thats not the prob. im going to try flushing out my coolant system next to see if its clogged.
dasauce17
Jan 24, 2011 07:05 PM
pepsicolla
Jun 4, 2008 09:13 AM
01AudiA4
Apr 17, 2008 02:24 AM
hartsoe1
Feb 8, 2008 05:14 PM
Wdmann
Mar 27, 2006 03:35 AM
