Stock Boost
Old Jun 12, 2006 | 02:48 PM
socaljoe's Avatar
SoCal Crew Member
Default Stock Boost
Yesterday I installed an AWE boost gauge. After the install was complete, I took it for a test run. In Park idle, gauge was showing -20 inhg, put in gear and it was -18 inhg. Driving the car around yesterday, the maximum boost was 14. This morning on my way to work, boost was maxing out at around 12, when I got to the parking lot and parked the car, idle was at -22 inhg and in gear is -20 inhg which is a tad lower than when I tested it yesterday, are these readings normal?
Old Jun 12, 2006 | 02:53 PM
dafrazi's Avatar
Default RE: Stock Boost
Looks good to me but I'm not 100% sure what the stock or chipped boost readings should be for a 2.0T. Vacuum readings look fine.
Old Jun 12, 2006 | 02:54 PM
north5995's Avatar
Between -22 and -20 is normal. I think mine sits at -22.
What chip are you running?
Don't forget that outside air temps will affect your boost. What was the temps yesterday when you were driving and today?
Old Jun 12, 2006 | 02:58 PM
socaljoe's Avatar
SoCal Crew Member
ORIGINAL: north5995
The car is not chipped yet, yesterday afternoon, it was in mid 70's. This morning it's in the lower 70's, a little humid
Old Jun 12, 2006 | 03:16 PM
ejc317's Avatar
those readings are kinda weird for a non-chipped car
Old Jun 12, 2006 | 03:43 PM
north5995's Avatar
ORIGINAL: ejc317
Its a B7.
I wouldn't worry about the readings. Give yourself a week to get used to the readings. The PSI reading will also be different depending on how hard you get on the pedal.
Old Jun 12, 2006 | 03:54 PM
b6driver's Avatar
12-14 psi is also my holding boost... no vacuum measurement here
Old Jun 12, 2006 | 04:46 PM
Beer Mod's Avatar
So it's safe to say a B7 runs 12-14 psi stock?
shon
Oct 13, 2017 04:20 PM
ebattilana100
Oct 19, 2008 04:01 PM
MK1audiTT
Apr 21, 2008 05:26 PM
mickey3c
Nov 27, 2006 01:15 AM
Piggy
Apr 5, 2006 09:38 PM
