stock turbo..how much PSI?
Old Feb 7, 2006 | 04:14 AM
freeunit's Avatar
Default RE: stock turbo..how much PSI?
alright sweet so i will definetly look into chiping
my question is do you have to send the ECU out to be burned.
how long does that take if so?
Old Feb 7, 2006 | 04:20 AM
freeunit's Avatar
hey what type of times do A4's run with exhaust and chip?
Old Feb 7, 2006 | 05:11 AM
a4's Avatar
a4
Is it a 99 or 99.5?
You'll most probably have to send it in to AWE, which will take about 3 days. The 2000s and up are flashable and apparently some 99.5s are too, but most likely you'll have to send it in.
No idea about the times.
Old Feb 7, 2006 | 05:35 AM
prodrive's Avatar
jeff ,7-9 sounds good to me but I can hit only 6 psi max.with my stock engine
Could it be leak on the lines ?
Old Feb 7, 2006 | 07:06 PM
Dave666's Avatar
Chip and DV at the same time.
go to www.goapr.com www.giacusa.com
Old Feb 7, 2006 | 07:50 PM
godwine's Avatar
Stock runs at 7 PSI the highest....
Old Feb 7, 2006 | 08:46 PM
toyolla86's Avatar
i wonder what they do when they put the chip in. i am in the navy as an electronics techinician and we have a mulit million dollar 2m lab that we can micro and mini solder. i wonder if i could open it up and do it myself. we have fixed an ecu off of an eclipse gsx before.
ic chips arent hard either.
smallturbo
Oct 19, 2011 04:10 PM
Hintzer
Sep 7, 2008 05:36 AM
mtnxtreme
May 27, 2008 02:15 PM
Poopie
10
Feb 12, 2007 11:24 PM
Dudek12
Feb 14, 2005 07:24 PM
