strange noise when turning slowly
Old Dec 28, 2006 | 02:58 PM
rnbguy's Avatar
Default strange noise when turning slowly
before i start i need you guys to know my car is pretty low and this may be a reason to this issue...
when i turn left (only) slowly my car makes a noise as if my wheels are slowly rubbing against something, but once i speed up (when turning) it stops, only happens when im going slow ... it happens in a motion noise too so it sounds like its happening with the motion of the wheels spinning, the noise is now getting louder and louder the more i leave it off...
what could this be?
Old Dec 28, 2006 | 03:10 PM
Pson's Avatar
Default RE: strange noise when turning slowly
ORIGINAL: rnbguy
what could this be?
Sound like your rubbing have the wife, buddy someone get in the car and turn the wheel while you look at it from the outside. See if its hitting and also just in case check the inner rim for grease and the rubber CV boot too. But jack her up and turn those wheels to find out
Old Dec 28, 2006 | 04:11 PM
SAudi's Avatar
it could be rubbing but im thinking wheel bearing. i thought the same thing about my car but i lifted the car up and held the suspect wheels at 9 and 3 and again 12 and 6, gave a little wiggle. i felt play in the right rear wheel, this usally indicates a worn wheel bearing. hope this helps.
Old Dec 28, 2006 | 06:39 PM
alaskanaudi's Avatar
i had this same issue with a 99 a4 2.8l quattro and found out later that my front suspension components were worn out therefore butchering my alignement and making it no longer keep allignment. on my car the noise was actually the tire itself rubbing the upper rear control arm and it got worn down to the wires before i realized it (road trip from washington to alaska driving home from college for hte summer) so not only did i get to replace the front suspension but also get a new set of tires. might want to check that out as well
Old Dec 28, 2006 | 06:44 PM
im_audi_herr's Avatar
i have the same problem. i checked for rubbing and any unusual wear on the tires and found nothing out of the ordinary. power steering fluid maybe?
Old Dec 29, 2006 | 12:30 AM
tractioncontrol's Avatar
Wheel bearing sounds are constant, theychange pitch and get slightly louder when you turn. I would check for signs of improper toe settings, like feathering in the tires. I think it is tire related, not that you are rubbing. If you were rubbing you should hear it at faster speeds also.
Old Dec 29, 2006 | 12:34 AM
rnbguy's Avatar
yeah i think so too, it started to happen when i had my tyres changed and it only got worse, its such an embarrasing noise, sounds like my car is farting slowly... i have to accelerate when taking off around corners so the noise goes away...
Old Dec 31, 2006 | 12:26 AM
rnbguy's Avatar
is there a write up toremoving the guards, it loks like the guards over the wheels have cracked due to the car being so low, i want to take them off completly...
Old Dec 31, 2006 | 01:58 AM
bluesnapper's Avatar
I know exactly the noise you are talking about. It is very loud inside the car, not sure about how it sounds from the outside. I sprayed silicone lube (very heavy) on all rubber suspension parts; control arm bushings, sway bar bushings, every pivot point I could see. The sound went away completely. Who knows what exactly it was or how long this will work. It might end up being a maintenance thing. Alland any rubber part will eventually dry up, silicone can helpdelay the process.
jvargas
Aug 4, 2014 10:52 PM
audi_sf
Dec 10, 2008 11:01 AM
Jc61990
Nov 5, 2008 04:38 PM
wigtontt
Dec 10, 2007 07:48 PM
psyct1
Apr 11, 2006 05:53 PM
