Strange Over heating Problem
Old Feb 24, 2007 | 10:02 PM
3.3turbo's Avatar
Default Strange Over heating Problem
Has any one come across a problem like this? My 98 1.8T start to run warmer and warmer until it eventually started to over heat. I have changed the radiator and thermostat twice. I have also checked for a blown head gasket. It still over heats, but when I remove the thermostat it runs fine except the heater blows clod even when the car is at operation temperature. When the thermostat is in the upper hose is hot and the lower is cold. I have boiled water to see if the thermostat is opening. It starts to open around 195.Any ideas?
Old Feb 24, 2007 | 10:10 PM
acetrebo's Avatar
Default RE: Strange Over heating Problem
Have you bled the air out of the system?
Old Feb 24, 2007 | 10:16 PM
smokeU's Avatar
water pump?
Old Feb 24, 2007 | 10:49 PM
wood_e's Avatar
Coolant temp sensor?
Old Feb 24, 2007 | 10:53 PM
JETSPEED333's Avatar
SoCal Crew Member
how about a heater core problem?
Old Feb 24, 2007 | 11:01 PM
3.3turbo's Avatar
Yes I did bleed the system. I also checked the heater core for good flow. The only thing I have not replaced is the water pump.
Old Feb 25, 2007 | 01:18 PM
david9999's Avatar
I'm a little confused by the thread.
If it runs fine without the thermostat then you have a problem with the thermostat. If you have replaced it and checked the opening temperature, are you sure that you are not inserting the thermostat backwards in the car?
Otherwise, if you are sure that you are installing it correctly, it sounds like a waterpump problem.
Old Feb 25, 2007 | 02:02 PM
techbod's Avatar
is the coolant fan cutting in??
DaveQ7
Audi Q7
Sep 16, 2014 01:58 PM
Sean2low
Nov 16, 2010 10:38 AM
lockee73
Dec 27, 2009 06:33 AM
jj2345
Aug 21, 2009 11:06 PM
re3188
Jan 21, 2009 06:18 PM
