striped drain plug...
Old Apr 4, 2005 | 11:40 PM
a4_b6's Avatar
Default striped drain plug...
I feel so stupid for this (so don't flame me) but I over tightened the drain plug previously and 3000 miles later,I just found that out that the plug is completely stripped while doing oil change...
Don't ask how I did it... last I changed the oil, it was too cold so I didn't bother using torque wrench thnking that it would be fine...and I feel real stupid for doing that...[sm=headbang.gif]
It's stripped and won't come off... Is there a way to salvage it still or do i need to replace the oil pane? [sm=boohoo.gif]
Any helpful tip is appreciated...
Old Apr 4, 2005 | 11:45 PM
ImolaS4's Avatar
Default RE: striped drain plug...
If you can't get it out, then you'll have to drill and remove it with a special tool. Obviously you'll need to get a new plug, but you shouldn't have to replace the pan.
Old Apr 4, 2005 | 11:47 PM
TomRitt's Avatar
you could try and easy out or try grinding a slot into the head and using a big screw driver
Old Apr 5, 2005 | 12:37 AM
apg96's Avatar
ORIGINAL: TomRitt
thats what i would do.
Old Apr 5, 2005 | 04:59 AM
acvega's Avatar
I did that last summer. I went to sears, bought a bolt extractor 1/2" socket and got it off that way. As you keep turning, it digs deeper into the bolt, it came right out for me after that.
Old Apr 5, 2005 | 02:48 PM
audihere's Avatar
Banned
no no no the pan is aluminium. use a helicoil kit from autozone, pepboys, and autmotive store near u. i stripped a bolt in my pan tried to re tap it and it didnt work bc it was aluminium and i used that kit and what a life saver. if that fails i have a oilpan i can sell u
Old Apr 10, 2005 | 08:43 PM
a4_b6's Avatar
Thanks for the info fellas!!
I want to salvage the oil pan so I'll try audihere's advice after I get the plug out... Hopefully the oil pan wasn't stripped too much...
Thanx again!!
Old Apr 11, 2005 | 01:59 PM
99a4audi's Avatar
dont worry one of my friends did that, we had to drill it out. it was a mess. had to get a new plug
Pirate
Sep 19, 2014 08:28 AM
hottubbrad
Dec 16, 2009 11:24 PM
TT4fun
Jul 28, 2008 10:16 PM
balkranjit
Mar 17, 2008 06:57 PM
werkwitdis
Jun 4, 2006 02:07 AM
