Super hard shifting (1st, 2nd, reverse) --b5 a4
Old Nov 3, 2007 | 08:52 PM
pyropenguin's Avatar
Default Super hard shifting (1st, 2nd, reverse) --b5 a4
So for the past few months, my car has decided that it's really picky about how it shifts and when it wants to shift. Sometimes it will shift very smoothly, sometimes I have to give it a little bit of force, and recently, it wont go into gear at ALL.
Reverse is giving me the most trouble, 2/3's of the time it wont go in anymore.
First gear is usually pretty hard to get into, it's only blocked me out a couple of times.
Second gear- if I'm over ~4500rpms in first, I can't get into it. If I let the rpms drop below that (keeping the clutch held in while the rpms drop) then it will shift fine, or if I just shift below that it's alright.
The rest of the gears are pretty trouble free.
What could be causing this? I'm guessing it's a shift linkage adjustment, but how do I adjust it? Would anything else cause this?
My car- 1998 1.8t 5spd... dieselgeek short shifter is the only relevant mod.
Old Nov 3, 2007 | 09:16 PM
jsgrabo's Avatar
Default RE: Super hard shifting (1st, 2nd, reverse) --b5 a4
i was having similar problems and a tranny flush took care of it.
Old Nov 3, 2007 | 09:46 PM
bob12312357's Avatar
Does ur tranny ever grind?
Old Nov 3, 2007 | 09:50 PM
I'll have to look into flushing the fluid.
Yeah it grinds sometimes if i don't shift into second fast enough (clutch all the way in still).
Old Nov 3, 2007 | 10:05 PM
Hows ur clutch cylinders and when was the last time u bled the system? Give em a peak b4 changin a tranny,especially if ur clutch has ever sunk 2 the floor or feels in any way odd.
Old Nov 4, 2007 | 01:13 AM
The clutch and brakes use the same fluid (+ fluid resevoir) right? That may have something to do with it... My brake fluid resevoir is cracked and I've been meaning to flush the fluid for a while.
A guy on audizine recommended that I adjust the shift linkage- can anyone explain how to do that for me?
tofast2belast
Jan 29, 2013 07:01 AM
pimpinb5a4
May 10, 2012 02:05 PM
shaferbm
Mar 23, 2011 10:04 AM
tmnelo524
Feb 27, 2011 01:15 PM
warranty225cpe
Oct 15, 2008 07:19 PM
