hard shifting sometimes.
Old Jan 23, 2013 | 01:19 PM
tofast2belast's Avatar
Default hard shifting sometimes.
can a bad clutch cause this problem that sometimes its hard to shift gear. going from first 2 second feels like its forcing it in gear, like the clutch didnt fully disengage. my clutch is bad and slips if i give too much throttle.
i just want to make sure that when i get my clutch replaced, this issue would be related and also disappear. i dont really feel like pulling the transmission apart to replace the synchros.
Old Jan 25, 2013 | 05:37 PM
anyone?
Old Jan 26, 2013 | 12:06 AM
MacValentine's Avatar
It could be the clutch. I had a syncro problem when I had my stealth. It just sounded like I was grinding even after I changed the clutch, but I never had a problem with it shifting hard. I would go a new clutch first.
Old Jan 27, 2013 | 09:42 PM
when i say shift hard, i mean its hard as crap to get it into the next gear. sometimes i have to rev match to get it to go in. i have bled the clutch line and same issue.
Old Jan 28, 2013 | 02:22 PM
but you haven't changed it yet, correct?
From what you're saying you're basically power shifting. Are you able to down shift easily?
Old Jan 29, 2013 | 07:01 AM
yes it is easier than upshifting. and the rev match is the only way to get it to shift smoother. i do still use clutch. but power shifting is keeping foot on gas pedal at full throttle while shifting. what i am doing is bringing the rpm up or down to match the next gear rpm speed so it will slide in.
i did adjust the shifter to shift linkage and it helped some but its still noticeable
507Derek
Oct 2, 2012 06:15 PM
pimpinb5a4
May 10, 2012 02:05 PM
tmnelo524
Feb 27, 2011 01:15 PM
warranty225cpe
Oct 15, 2008 07:19 PM
bruin4ever
Jun 19, 2007 08:41 PM
