synthetic oil for my 2.8?
Old Feb 28, 2006 | 09:34 PM
  #21
headshok2002's Avatar
Default RE: synthetic oil for my 2.8?
ORIGINAL: beefski
The material is not as high quality as the Mann or Mahle. I was told this by an audi only mechanic. Mann or Mahle is the only filters to use.
Yeah but really, what does a mechanic know about the materials inside an oil filter... haha, they look identical as far as the eye can tell... Mechanics just screw them on and off... they don't do scientific tests on them... even 'audi only' mechanics.
Old Mar 1, 2006 | 01:52 AM
  #22
John_E's Avatar
To learn more than you could ever want to know about engine oils, refer to BobIsTheOilGuy.com.
I use the Wix / Napa Gold 1191 in the Audi 2.8 12V, with either a good dino oil or a synthetic. I am currently using a blend of 5W-30 Valvoline high-mileage synth and 10W-40 Valvoline high mileage dino. I vary the mix seasonally, with more 5W-30 for winter cold starts and more 10W-40 for summer high temperature protection. Dino oil should be changed more frequently than synthetic, but otherwise should be fine for this engine.
The 1.8T is a different story. I use Mobil 1 0W-40 exclusively in my 2001 Passat, with either the 068-115-561B filter or the even larger "Mann-made" Purolator L40316. Oil and filter choices are far less critical with the V6.
Most Bosch and VW branded oil filters I have seen are made in USA, reputedly by Champion Labs. If you are paranoid about oil filters, stick with Mann, Mahle, etc.
Old Mar 1, 2006 | 01:55 AM
  #23
John_E's Avatar
ORIGINAL: headshok2002
Hmm... isn't the 40 thicker, though? Audi's #1 recommended oil is 5w40... but since mobil doesn't make it, they suggest 0w40... the 40 is @ temperature, no? 40 seems to be the important # here... haha
Mobil 1 DOES come in 5W-40, which should be a fine oil choice for either the V6 or the 1.8T, although 1.8T owners should probably stick with 0W-40 as long as the powertrain and oil sludge warranties are in force. The only practical difference between 0W-40 and 5W-40 is that the former will remain liquid at extremely low temperatures, which would be a concern only way up in the snowy north.
Old Mar 1, 2006 | 01:58 AM
  #24
StevenTownsend's Avatar
5x,xxx miles on a 96? gj.
alinux
Oct 27, 2008 12:38 AM
gotBoost?!
Aug 24, 2007 12:29 AM
blkapra4
Jul 9, 2006 11:03 PM
melange_not_tan
May 25, 2006 12:09 AM
hotgue
Mar 20, 2004 05:01 AM
