system to lean (bank 1)
Old Oct 31, 2007 | 06:01 PM
seana4's Avatar
Default system to lean (bank 1)
I have another check engine light p0171 system to lean (bank 1) any suggestions? to fix
Old Oct 31, 2007 | 06:08 PM
turbo kraut's Avatar
Tech Guru
Default RE: system to lean (bank 1)
when i had that issue it was my maf... if there is someone around you with an audi, you might ask to try their maf and then get the code cleared drive around and if it dioesn't show a code, get a new maf from the vw dealer, will save you about 150 bucks
also do you have a boost guage? if so what psi are you running at?
Old Oct 31, 2007 | 06:11 PM
A4Tuner.'s Avatar
ORIGINAL: seana4
usauly when this comes up on mine its just the vacume hoses on the intake manifold. in other words you might have an air leak after the maf somewhere. just start the enigne and listen for any air leaks around the intake and hoses, move them around abit to see if one is cracked.
easy diagnostics lol
Old Oct 31, 2007 | 06:15 PM
Tech Guru
it is pretty different on the 1.8 motor.......normally a maf, you might also try getting some electronics cleaner and clean the maf
Old Oct 31, 2007 | 06:16 PM
Tech Guru
https://www.audiforums.com/searchpro...bmitbutton=+OK+
also look through some of these threads
Old Oct 31, 2007 | 06:23 PM
A4Tuner.'s Avatar
ORIGINAL: turbo kraut
yea. seana4 if yours 1.8 or 2.8?
BesI
Aug 27, 2012 03:02 AM
rwb
Jan 5, 2011 05:07 AM
Sp33d07
Aug 14, 2008 01:27 AM
01A4T
Nov 30, 2006 02:01 AM
gcain99
Aug 12, 2005 12:40 AM
