temp gauge intermittently not working?????
Old Mar 9, 2006 | 04:37 PM
rbrtech's Avatar
Default RE: temp gauge intermittently not working?????
Engine Coolant Temperature (ECT) Sensor -G62-, Checking
Special Tools and Equipment
VAG1526A
VAG1594A
VAG1598/31
VAS5051 with VAG5051/1
Test requirement :
Engine cold
Test sequence
Connect VAS5051 tester and select vehicle system "01 - Engine electronics". Engine must run at idle for this. Refer to "Scan Tool Testing/Scan Tool Connecting and Initial Checks/VAS 5051 Tester, Connecting and Selecting Functions" See: Powertrain Management\Computers and Control Systems\Testing and Inspection
Display on VAS5051:
Select diagnostic function "08 - Read Measuring Value Block" in selection -1-.
Display on VAS5051:
1 - Enter display group Max. input value = 255
Select function "004" in button field -2- for "display group number 004" and press Q button to confirm input.
Display on VAS5051:
Check coolant temperature sensor in display field -3-.
Display Group 004
Press "08 - Read Measuring Value Block" to end function <- button.
If display field 3 does not have a realistic indication:
Disconnect connector at coolant temperature sensor.
Connect multimeter between terminal C and D of sensor for resistance measurement.
Range A shows the resistance values for the temperature range from 0-50 °C , and range B shows the values for the temperature range from 50-100 °C .
Read-out examples:
30 °C corresponds to a resistance of 1500 to 2000 ohms W
80 °C corresponds to a resistance of 275 to 375 ohms
If specified value is not obtained:
Replace coolant temperature sensor.
If specified value is obtained:
Connect VAG1598/31 test box at wiring harness to Engine Control Module (ECM), do not connect ECM. Refer to "Scan Tool Testing/Wire and Component Testing Using VAG1598/31 Test Box" See: Powertrain Management\Computers and Control Systems\Testing and Inspection
Check the following wire connections for open circuit and short circuit to Ground (GND) and B+:
Check both wires to each other for short circuit.
Repair open circuit or short circuit if necessary.
If no malfunctions are found in wires:
Replace Engine Control Module (ECM).
Old Mar 9, 2006 | 04:38 PM
rbrtech's Avatar
Maybe those will help there are both. Must get to work now.
Old Mar 9, 2006 | 09:12 PM
rnbguy's Avatar
excellent now i gotta dig up vag from under my bed somewhere
Old Mar 10, 2006 | 08:40 PM
haveaseat's Avatar
Member
ok yeah the oil temp goes up....and rnbguy thanx for all the info but i dont have the scan tool lol
Old Sep 24, 2007 | 03:24 AM
gurcharan's Avatar
Hi guys,
I have a 2004, 1.9tdi 130, has the same issue, while driving the temperature falls to zero and then back up to normal, i was assuming it was a fault with the temp sensor, but not sure as its intermittent.
Anything you can suggest for all us users who don't have the diagnostic tools?
Cheers
Old Jan 16, 2021 | 08:41 PM
Gary Gershon's Avatar
Default Temperature gauge inconsistent
2004 Audi TT quattro--twin turbo. 166,000 miles. Twice recently, the gauge would not come up to middle. First time, it was on first indent. Then, it worked fine again. Today. same issue except now only goes to second indent. Ideas? Bad gauge, sensor, or is the engine running too cold? Thank you.
Old Jun 12, 2024 | 01:43 PM
PercivalShortz's Avatar
Originally Posted by haveaseat
ok i gotta 2001 a4 quattro 2.8 30v....its got 77k on the clock and just recently my temperature guage started not workin intermittently...cant find a constant as to when it stops workin or starts again....but i did notice this, when the car is runnin it registers full cold but it does lift a lil tiny tiny bit from when the car is off and no power is goin to it......any ideas on what this can be? im hoping its not the cluster cuz i dont wanna have to go thru all that....please some1 out there tell me they had this problem and it was just the temp sensor or something?
Very common failure. Dont think ive every see a problem with the cluster as far as the engine temp is concerned.
Shawn4
May 29, 2016 04:47 PM
crazyquik22023
Oct 21, 2011 11:01 PM
Bklynrx7
Apr 21, 2009 12:55 PM
Lazer Viking
Sep 12, 2006 10:06 PM
haveaseat
Mar 8, 2006 12:31 AM
