tempature reading
Old Sep 2, 2006 | 03:10 AM
johnstef's Avatar
Default tempature reading
i have a 1999.5 a4 and i was wondering if there is a was to ajust tempature reading.
One day it just went crazy and was droping until it hit negative 58. then it went back but it reads like 8 deegres higher then what it is oustide.
Old Sep 2, 2006 | 04:44 AM
AudiCross's Avatar
Default RE: tempature reading
Im not sure exactally what these things work with calibration, but i know i have a 2001 a4, and the temp isnt great either. it doesnt spaz out like that, but it is almost allways anywhere form 2-15 degrees high. and thats when driving, so its not from heatsoak. it must be these bulbs, when they get old, they trip
Old Sep 2, 2006 | 12:49 PM
audi_pa's Avatar
yeah mine did that it would go from 80 to 32 degrees then slowly climb back up then down. i scanned the car and i did get a code for it too. and it was the outside air temp sensor this is what the code looked like
1 Fault Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
30-10 - Open or Short to Plus - Intermittent
Old Sep 2, 2006 | 01:28 PM
acetrebo's Avatar
replace the outside temp sensor, or at least inspect the harness, clean and use some di-electric grease and see if that helps.
Old Sep 2, 2006 | 03:35 PM
johnstef's Avatar
where is the sensor?
Old Sep 3, 2006 | 03:47 PM
dankhound's Avatar
Behind the bumper. Its mounted to a near the bottom of the radiator. You should be able to see ith thru the grills.
Old Sep 3, 2006 | 04:01 PM
audi_pa's Avatar
yep
Old Sep 5, 2006 | 03:49 AM
johnstef's Avatar
i lok at the front of the radiator nothing.... i see this cord that runs to the front radiaore but is not plugged in anything. Can i not have a sensor and. thats why its is offf. I dont undersdtand help!!!!!!!!!
A4driver17
Jan 6, 2012 11:47 AM
A4driver17
Jun 23, 2011 11:49 PM
JcoyA6
Apr 16, 2008 06:46 PM
trejo21
Nov 1, 2006 02:29 AM
nazar2350
Mar 17, 2006 05:54 PM
