ticking sound?
Old Jul 19, 2005 | 06:45 PM
  #31
VolcanicBlackA4's Avatar
Default RE: ticking sound?
bump...anyone know what the problem is?
Old Jul 19, 2005 | 09:59 PM
  #32
richsnipe's Avatar
Might be the cam chain tensioner and/or chain. Mine makes some noise, but rattles/resonates pretty bad around 2500-3500 rpm when the engine gets hot. I took the valve cover off yesterday to see if there was any signs of wear, and didn't find any. From what I heard it might be better if the dealer does it if it IS the cam chain tensioner. Hope this helps.
Old Jul 19, 2005 | 11:14 PM
  #33
BFlan2001's Avatar
maracas don't tick, you'll have to describe the sound better
Old Jul 19, 2005 | 11:59 PM
  #34
droo587's Avatar
i still dont know...........a friend of mines with a lexus gs had the ticking. He got his timing belt fixed and its ok now, can the ticking sound be the sign of a timing belt? lol im at 84k now, still have had the time to do the belt
Old Apr 10, 2007 | 05:26 PM
  #35
snooper's Avatar
hi I also have this sound but only recently started to happen is there a cure???????
Old Apr 10, 2007 | 05:41 PM
  #36
nickellis14's Avatar
its not your pistons hitting your valves. thats ridiculous. however, look into changing your oil (and using SYNTHETIC) and make sure you use the highest octane gas you can buy. if that doesn't fix your problem, then check into the timing belt.
if your pistions were knocking against your valves I have problems believing that your car would still be running.
yellow_submarine
Oct 19, 2011 12:02 PM
slivka
Jan 28, 2008 09:16 PM
redsapphire89
Dec 10, 2007 10:44 PM
JCatt9
Apr 10, 2007 12:01 AM
