time to change the timing belt...
Old Sep 24, 2005 | 03:35 AM
gbot's Avatar
Default time to change the timing belt...
car has 94000kms on it and im thinking im overdue on a timing belt change...i looked at the kit from ecs and im wondering is this kit the one...or can i get buy without doing all of it...much help would be appreciated...
2001 Audi A4 1.8T Quattro Tip
Old Sep 24, 2005 | 08:16 AM
sandman's Avatar
Default RE: time to change the timing belt...
TB failure is usually due to something other than the timing belt failing its self, so its a good idea to replace all that stuff.
heres a writeup that i found helpfull.
http://www.audiworld.com/tech/eng.html
its in there just scroll down.
Old Sep 24, 2005 | 01:24 PM
CRAZYHAWK's Avatar
Call ECS Tuning,give them your VIN and they'll send you the correct kit. You should replace the tensioner, damper pulley and water pump.
Old Sep 24, 2005 | 08:56 PM
david9999's Avatar
And front engine seals, and if you want the snub mount
Old Sep 25, 2005 | 04:28 AM
gbot's Avatar
my car is a tip...is the snub mount going to make a difference...for 50 dollars ish...i guess its not really an expensive upgrade...but this is going to sound dumb, but wouldn't i notice it more if my car was a manual?...im not sure...still trying to learn about my car...
Old Sep 25, 2005 | 10:20 AM
david9999's Avatar
I have a tip and it did make a difference, however, it took a lot of work to get rid of vibrations. I'd be careful based on my experience.
CitizenSnipz
Jan 29, 2012 07:36 PM
ckappler
Sep 7, 2009 04:10 PM
FortyCal
Oct 24, 2007 07:32 PM
tuckerm
Mar 13, 2006 05:19 AM
socalaudi
Mar 13, 2006 02:39 AM
