TIP Transmission grinding
Old Mar 12, 2009 | 05:08 PM
SloRide's Avatar
Default TIP Transmission grinding
We have a 98 A4 automatic that will not go into gear or move at all. When i shift to the 'drive' position there is a loud grinding noise coming from the engine bay (front right side) and it just sits there. If i return to 'netural' the sound goes away. I get the same sound if i shift to 'reverse'. There are no lights up on the dash or codes i can see out of the obd port. Any advise on what to check? I do most of my own work but i broke my foot and i'm in a cast, so all i can do is look and point at things and let my son take over from there. Any suggestions would be apprecitated.
Thanks
Old Mar 13, 2009 | 04:05 PM
brrman's Avatar
Does not sound promising if the car will not move. You say you read the OBDII and got no codes at all??
Jmann
Oct 8, 2012 12:39 PM
denverguy
Sep 19, 2008 03:19 AM
Brandon2000s4
Jan 16, 2007 06:27 PM
Johnny225
Jan 14, 2007 04:49 PM
dubiousmusic
Sep 10, 2005 06:53 PM
