transmission grinding
So I'm new to Audi's. I just bout a 2001 a4 quattro, its 5 speed manual. I was just driving and it seems as I don't have 2nd, 3rd or 4th gear. I can find 2nd 3rd and 4th but i have to really slam it into the gear and all it does is grind, not engage. 5th and reverse are fine, and 1st gear engages but i have to rev it up to between 2 and 3 grand and it finally catches, and then takes a second or two to fully engage, kind of revs first. I can also push the clutch to the floor in first gear, then hit the gas and ill still be accelerating. Does this sound like my clutch?
Just got done bleeding it. Still have the same problem. it now feels as if the whole tranny shifted to the right though. for example. First is where 3rd should be and 2nd is where 4th should be. 3rd 4th 5th & reverse are in the normal smopts though. Do you guys think a spring could have popped outta the clutch and got jammed between the clutch and flywheel?
