Tiptronic info: Late shifting after going uphill
Old Feb 16, 2006 | 07:35 AM
TroyS's Avatar
Default Tiptronic info: Late shifting after going uphill
Thought i'd post this hear for anyone that could use the info, i've been searching for it for days. My 98 A4 1.8t FWD has a problem where it shifts late after going up an incline. It'll be in 1st or 2nd and when i get to the top of the hill and flatten out, it wont upshift until 3,500 to 4,000+ rpm. It really worried me, but at least its fixable. It requires an updated Transmission Control Unit (TCU). There was a technical service bulletin about it.
Anyway, heres a lot more info on the passat forums.
http://www.passatworld.com/forums/sh...ad.php?t=96605
Old Feb 16, 2006 | 12:55 PM
onepoint8tee's Avatar
Default RE: Tiptronic info: Late shifting after going uphill
Interesting.. They changed the coding for the TCU in 2000 which has been talked about many times (mostly by me)... But if you have vagcom you can code your early model tipttronic to the way the 2000's are. I coded mine for the old style like yours because the shifts are smoother and it eliminates the kickdown function when you are in tip mode. The newer coding (2000 and up) is much more "automatic" shifting but may eliminate what you are talking about. Ive never experienced what your talking about though. Check out Rosstech.com and search for the "Transmision coding" DIY for vag com..
Old Feb 16, 2006 | 02:31 PM
avanttripleloop's Avatar
imagine that ,i have that problem also.thanks much for the post.
Old Feb 16, 2006 | 02:41 PM
black991.8tq's Avatar
yea ive noticed the same thing,mostly when the car is cold. there is a huge windy hill by my house.......i dunno if its a problem or not.
Old Feb 16, 2006 | 02:47 PM
techbod's Avatar
yep its a software upgrade problem find out if its a recall
Old Feb 16, 2006 | 02:58 PM
Jovian's Avatar
I also have this issue on my 99.5
Old Feb 16, 2006 | 04:07 PM
2 dealerships today have had no knowledge of this,imagine that.
Old Feb 16, 2006 | 04:16 PM
TroyS's Avatar
Mine didn't either
Old Feb 16, 2006 | 10:49 PM
mdeerfield's Avatar
98.5 A4 1.8T tip - same thing.... high revs in 4th on uphill. So - what happens to the tip behaviour if you change the program to the newer style ?
Does the re-program also change the short shifting pattern while in automatic ?
Old Feb 16, 2006 | 10:53 PM
Time for a tip chip!!!!
1998audiA6_Q
Mar 10, 2013 10:58 PM
pimpinb5a4
May 10, 2012 02:05 PM
CrazyPete
May 4, 2009 09:57 AM
8cyls~of~love
Feb 7, 2008 12:51 AM
lnewman
Jan 22, 2008 05:27 PM
