Tire myth or truth?
Old Feb 18, 2005 | 08:18 PM
lvnnsn72's Avatar
Default Tire myth or truth?
I have an '01 1.8t Quattro. Had a front tire go out on me recently. I wanted to replace only the front two tires b/c all four are relatively new $$$. Independent tire dealer tells me he will only replace all 4 at a time b/c all-wheel drive (liability for transmission failure???). Dealer told me to replace front two and it will be ok regarding quattro/trans. Should I eat the cost of new tires, or is it ok to replace fronts only? Anyone w/ experience please comment. Thanks.
Old Feb 18, 2005 | 09:29 PM
PandaXpress's Avatar
Default RE: Tire myth or truth?
if u replace the front only the ride wont be as nice as befor though i dont think it would trash the tranny though
Old Feb 18, 2005 | 09:48 PM
Shaunp05's Avatar
You can replace there front two tires only, try and make sure you have the
same tread pattern on the tire.
I would put the new ones on the rear and Balance the rear and put them on the front
If It was a front wheel drive you would have to replace all due to oversteer
from the front having more traction then the rear
Old Feb 19, 2005 | 01:20 AM
lvnnsn72's Avatar
Thanks for the fast reply. I figured that the front wheels would be best to have the new rubber since they are the steering wheels. And don't the fronts typically wear faster on all cars (front/rear/all-wheel drive)...?
Old Feb 19, 2005 | 01:24 AM
lvnnsn72's Avatar
Yeah, not so worried about the ride quality, just wanted to debunk the transmission failure theory. I had another tire guy tell me that Subaru voids their warrantly if you don't replace all four at a time.
Old Feb 19, 2005 | 12:39 PM
CRAZYHAWK's Avatar
Get the same 2 tires as the other axle make, model and size. You'll be OK.
exequiel3k
Jun 6, 2010 10:02 AM
rorty
Aug 27, 2007 01:20 AM
Boober
Nov 28, 2006 12:57 PM
blackhawk411
Sep 28, 2006 01:15 AM
guy022077
Nov 28, 2005 08:28 PM
