TIRE RECOMMENDATION
Old Aug 12, 2005 | 08:43 PM
BLAZEDUPBEE's Avatar
Default TIRE RECOMMENDATION
i got a guy sellin me some HP EVOs 18x8.5 wheels for a good price. they come with new tires they are as follows 245/35/18 in the front and 275/35/18 in the rear. they were mounted on a a6. is the bolt pattern the same? will this fit my car nicelly (a4 quattro 1997) i dont want my car gettin messed up or the wheels/tires sticking out the wheel well either! keep in mind i plan on dropping the car atleast an inch. what is an ideal size for the tire? all info is appreciated thanks..
Old Aug 12, 2005 | 08:44 PM
PandaXpress's Avatar
Default RE: TIRE RECOMMENDATION
they're staggered wheels and the A6 has the same bolt pattern as us 5x112
Old Aug 13, 2005 | 05:46 PM
so if i was to buy them wouldnt that mess up drive shaft and all the other goodies? since its "staggered"? he told me they were 18x8.5 i just forgot to ask him if it was all around.
Old Aug 13, 2005 | 07:12 PM
dafrazi's Avatar
The different sizes could cause problems with the ABS.
Old Aug 14, 2005 | 01:26 AM
AWDaholic's Avatar
Senior Administrator
Bigger problem will be the decrease in turning radius with a staggered setup on a Quattro. Less noticable will be the slight decrease in turn-in response, but it will be there, nonetheless. That much rubber, with that much stagger is diff gonna make a noticable affect on your turning radius w/quattro, IMO.
Old Aug 14, 2005 | 03:34 PM
JDCrowe's Avatar
wont the different tire sizes also screw with the tranny b/c of the AWD ??
Old Aug 14, 2005 | 04:24 PM
headshok2002's Avatar
your rear tires overall diameter is 25.5", where your fronts will be 24.7"... thats 3/4 of an inch difference in diameter dude, which means your front wheels will be spinning substantially faster than the rears, which WILL cause damage to your quattro.
Aside from that, you'll NEVER fit a 275/35/18 in the rear... EVER. that is a hugely wide tire!
R3N3G4D3
Mar 9, 2010 04:35 PM
cmatson
Jan 8, 2010 10:38 AM
RonD2000
Feb 17, 2008 08:28 PM
oleg_too
Sep 25, 2005 03:22 PM
kayk2
Jul 15, 2005 07:05 PM
