tire size
Old Dec 14, 2005 | 06:03 AM
4ringstuned's Avatar
Default tire size
Is it possible to fit a 245 width tire on a B6 A4 or will it start to rub?
Old Dec 14, 2005 | 01:12 PM
headshok2002's Avatar
Default RE: tire size
Yeah you could probably do it... I am sure you could do it if you aren't lowering it. I have never heard of a car where you can't go a little wider. But if you plan on dropping the car, who knows... But, you can always just turn the wheel in either direction to its furthest point, and inspect how much room you have.
Old Dec 14, 2005 | 05:24 PM
VitaminB6's Avatar
I considered 245's but was not convinced they would fit so went with 235's instead (mounted on 19x8.5'w with 38MM offset). The extra .39 inches would push out each edge of the tire by .2 inches, which would probably fit for stock or sport suspension without rubbing, but I would recommend careful measuring if you plan on lowering. If you are using a different offset, then use this offset calculator to determine the impact.
BTW, I find that the fender wells are nicely filled out with the 235's, and so I am glad I didn't go wider.
Old Dec 14, 2005 | 10:45 PM
thanks a lot. both of you real helpful!
mystrodo
Sep 2, 2009 09:41 AM
fidelite
Jun 24, 2008 02:06 PM
EliteTuning1
Jul 25, 2007 04:15 PM
jtv4.2
Aug 29, 2006 02:00 PM
angelo_nyc1
Jan 7, 2005 06:33 PM
