Tranny fluid as an engine laxative?
Old Oct 15, 2004 | 07:30 PM
DarkHelmet's Avatar
Default Tranny fluid as an engine laxative?
Folks,
I've been researching an oil sensor light problem on this site and have seen a couple mentions of running a quart of auto tranny fluid in the engine oil to periodically clean things up... is this indeed a normal practice? I've used 'purpose' chemicals for this but only on old beaters, not something as nice as an Audi (with 1.8T, 61k miles, yes, time for the belts too).
I have used nothing but M1 changed at 3-5k intervals... does a "Dex-Lax" flush still make sense?
Old Oct 15, 2004 | 09:10 PM
CRAZYHAWK's Avatar
Default RE: Tranny fluid as an engine laxative?
Engine should not be hot.
I'd first check the oil. Pull the dip stick out. Rub the oil between fingers. If the oil is smooth it's good. Replace the dipstick.
Remove the oil refill cover. Put a finger on the inside of the valve cover , and feel for sludge. If you only feel smooth oil it's good. Replace the oil cover
Old Oct 16, 2004 | 06:53 AM
SlimChriz's Avatar
Use motor flush. follow the instructions dont drive with it in you engine
Old Oct 19, 2004 | 04:13 PM
brrman's Avatar
Use recommended fluids for engine cleaning. Tranny fluid is not reommended.
Old Oct 19, 2004 | 10:36 PM
David_K's Avatar
I know ive said this b4 somewhere but i thought that on older cars the "sludge" is what is keeping oil from leaking.
Old Oct 20, 2004 | 04:33 AM
brrman's Avatar
Default .
Regardless of whether or not it keeps it from leaking, you should try to get away from oil sludge. If you have a leak you should fix it - not let sludge clog it up.
Old Oct 20, 2004 | 01:57 PM
Doose's Avatar
Default RE: .
My performance shop reccomended that I do that when I had the sludge problem. I only ran it for a couple hundred miles and changed the oil and filter after the first hundred. That's really important because it will fill up an oil filter quickly.
Old Oct 20, 2004 | 02:14 PM
David_K's Avatar
Default RE: .
What will fill up the filter quickly? what exactly did you use? didnt you have the dealership take care of that? can you send me the email that you were sent reqarding the recall?
Old Oct 20, 2004 | 11:36 PM
Doose's Avatar
Default RE: .
The sludge cleaned out by the auto tranny fluid. It filled up one filter in about 100 miles and the second in another 100. Yeah, ultimately Audi did take care of it, but initially I had to deal with it. It wasn't until about three months after the fix that I got the letter from Audi. I'll email you the details and a copy of the letter from Audi.
jamm220
Sep 19, 2011 08:22 PM
TraineeV2
Feb 22, 2008 03:53 PM
a42point8awd
Nov 9, 2007 11:56 AM
johnstef
Dec 6, 2006 08:37 PM
