Tranny worn out maybe?
Old Jul 21, 2006 | 05:03 AM
16w/A4's Avatar
Default Tranny worn out maybe?
I have a 96 a4 auto quattro with 70k on it, when i pull to a stop sign (or any quick stop) and put the car in 2 and start again it will sometimes (very rarely) rev up like it is neutral and then jolt all of a sudden like i have a manual and rev it up and let out the clutch? is this the computer being confused or a problem. today it was more serious as i felt a bit of a slip at like 4500rpm. I dont drive the car hard very much and the guy before me didnt (he said) either, what could this be from
Old Jul 21, 2006 | 05:57 AM
16w/A4's Avatar
Default RE: Tranny worn out maybe?
no thoughts?
Old Jul 21, 2006 | 07:04 AM
techbod's Avatar
change the tranny fluid and filter, the same thing happened to me and this sorted it.
one other good point is the auto tranny has a rubber gasket and it can be re-used
Old Jul 21, 2006 | 07:40 AM
16w/A4's Avatar
the tranny had a full service like 6 months ago, new fluid and seals and everything, maybe ill get it checked up
Old Jul 21, 2006 | 09:50 AM
david9999's Avatar
I would. What kind of fluid was put in and what kind of mechanic did it?
Check also for codes from the transmission control module.
Old Jul 21, 2006 | 08:06 PM
16w/A4's Avatar
i hope they used the right fluid, it was a pretty big german car garage, and ill try to get codes
Old Jul 21, 2006 | 09:18 PM
david9999's Avatar
If it was a german garage, they probably used the right stuff.
Is the transmission a tiptronic or just a regular automatic. and yes, you can get some jolt if you shift down into second at too high a rev. There is also probably some driveline slack.
Old Jul 22, 2006 | 12:02 AM
audia4quattro's Avatar
supid question, but i looked everywhere to put in the tranny oil and can't find it. Can someone please point it out to me please!
Old Jul 22, 2006 | 04:30 AM
16w/A4's Avatar
it is a normal auto, i dont switch into second at high revs , i do it at idle before ill drive off every now and then, i think its fine, i was just worried that it slipped in the rev up at like 30 mph in 1st gear
Old Jul 22, 2006 | 12:36 PM
david9999's Avatar
ORIGINAL: audia4quattro
It is a sealed unit. The car has to be on a lift and accessed through a filer hole that has a screw in seal.
jsheeder
Oct 6, 2014 08:26 PM
vtraudt
May 16, 2011 04:25 PM
alinux
Sep 18, 2007 08:48 AM
waveblaster200
Jul 21, 2007 02:10 AM
SAudi
May 10, 2007 09:07 PM
