Transmission in "Save Mode"????
Old Jan 20, 2006 | 04:55 PM
mikehh's Avatar
Default Transmission in "Save Mode"????
All my gears are lit up on the panel and it seems like the transmission won't shift into the fifth gear. Someone said that when all light are illuminated, the transmission is in some sort of "save mode". Does anyone know if I can get some sort of error code reading before trying to find out what the problem is? Also, is there any way to reset it?
Any help is appreciated,
Thanks!!!
Old Jan 20, 2006 | 05:06 PM
InsaneHatter's Avatar
Default RE: Transmission in "Save Mode"????
your tip could be shorted out, did you wash anything inside your engine anytime soon?
try to get someone w/ a VAG-COM to scan you car.
If there is corroision on some contacts you may have to clean them out
Old Jan 20, 2006 | 06:08 PM
PandaXpress's Avatar
no did u over rev the car u kno like u thought u where in tip but u where in D and u shhifted to neutral and over rev the car
if its nuthing serious the safe mode should go away
Old Jan 20, 2006 | 08:37 PM
mikehh's Avatar
The shorted tip does make sence. We had some flooding two days ago, where i see this could have happenend. If so, is there any way to reset it?
Thanks for the hint!!
Old Jan 20, 2006 | 08:42 PM
tip5's Avatar
Man hope for the best expect the worst Mine did that and i had to do a full rebuild.
Old Jan 21, 2006 | 07:02 PM
mikehh's Avatar
anyone else????
venechamito
Aug 18, 2013 09:28 AM
madgunz
Apr 21, 2011 12:36 PM
jpcallmotor
Jul 9, 2010 01:41 PM
audia4doc
Jun 27, 2008 12:52 AM
badge424
Dec 20, 2007 03:13 PM
