Transmission question(already used search.)
Old Jan 30, 2008 | 09:00 PM
Rdssk8boardr69's Avatar
Default Transmission question(already used search.)
hokay, i NEED to change my transmission fluid before i do anything because i need to cover the less expensive bases first. I have access to a full garage with lifts oil tubs for drain i mean this garage has EVERYTHING. I have used search and haven't really found anything as to HOW to chagne the fluid and possibly the filter. I know it is a sealed transmission but have read i can buy a special bit to open it up to drain and fill? and what about the filter? It would be great if someone could either tell me or point me to how i can
-drain tranny fluid
-fill up to appropriate levels
-and change filter
I am almost flat outta money and need to be able to fix this myself i just replaced the turbo so i'll be damned if i gotta pay 1k+ to replace this!
I have a 2000 a4 atw 1.8t with a tip transmission
thanks
Kevin
Old Jan 30, 2008 | 09:09 PM
qUaTtRoA4's Avatar
Default RE: Transmission question(already used search.)
shoulda checked our DIY section...though this is for a 5 spd...ionno what the difference would be exactlly
https://www.audiforums.com/m_156758/tm.htm
gl!
chaos92287's Avatar
you need the drain plug tool and a vagcom or similar diagnostic software that will allow you to monitor temps. but i dont know the exact process
Old Jan 30, 2008 | 09:32 PM
auditech help me out maybe?
Old Jan 31, 2008 | 12:40 PM
SLVR99A4's Avatar
Go to Blaughparts.com and click on their AT transmission kitsand it will link you to an exact step-by-step instruction manual that has clear visuals on how to do it. Like previously stated, hopefully you have access to a vagcom as this is critical for monitoring fluid levelsat proper ATF tempertature. You will need atleast 6 qts of the required Pentosin ATF.
Old Jan 31, 2008 | 09:17 PM
oldgearhead's Avatar
I think you mean Blauparts.com?
Old Jan 31, 2008 | 10:02 PM
SLVR99A4's Avatar
^ correct.
indyrich
Audi Q5
Feb 18, 2014 10:56 PM
trizzlebomb
Nov 18, 2007 02:01 PM
lakesailor
Feb 19, 2007 12:37 AM
LeVeL
Dec 30, 2006 03:45 AM
