Transmission will not move any ideea.
Old Feb 11, 2007 | 04:37 PM
xavx1's Avatar
Default Transmission will not move any ideea.
Ok i needed an ew transmission to be put in. After i had the new transmission put in the car will not move at all. It worked for 5 minutes. Now you turn it on and the car will not move the car seems to be in neutral. And after 1 minute the dash will light up. Any ideea. do i have to reset the computer or something???? Please help.
Old Feb 11, 2007 | 04:41 PM
techbod's Avatar
Default RE: Transmission will not move any ideea.
more info required, did you fill it with atf
Old Feb 11, 2007 | 07:34 PM
wood_e's Avatar
Uh, yeah, what year, engine, transmission type? Where'd you ger the transmission?
Old Feb 11, 2007 | 07:51 PM
xavx1's Avatar
Audi 2000 A4
Engine ATW 1.8 Turbo
Trans. EFP Auto
Engine Miles 50,000
New Trans. Audi Rebuild Off a 35,000 miles audi
ATF- Audi special Hidraulic
Now i`m getting service engine soon. ??? odd
It worked fine for about 5 minutes. Do i have to reset the computer or something. ??
Old Feb 11, 2007 | 08:16 PM
david9999's Avatar
The service engine soon is just a light to tell you you are due to an oil change.
Who installed the transmission? Did you check to see that the transmission control unit is set correctly for your transmission..
What was the initial problem that you had that you "needed" a new transmission for?
Are the lights on the dash normal for the gear, or are they all lit up in the background with the numbers dark/
Old Feb 11, 2007 | 08:36 PM
xavx1's Avatar
I found out that audi had a recall on the engine so mine was haveing problem and i got the engine swaped. That was a year ago. Now the torque converter was stuck and the first gear was burned out. A new trans was needed. I took the car to a shop and i bouth the same trans. with the same code. Same year. Yes the car starts and after a minute all the P R N D 3 2 get light up and thats it.
Old Feb 11, 2007 | 11:21 PM
david9999's Avatar
Your transmission is in safe mode. You will need to have the codes pulled frm the transmission control unit with a real vagcom. It could just be that the TCU is not set correctly, or one of the sensor cables has not been reconnected. If you had a garage do the transmission swap have them fix it
Old Feb 12, 2007 | 04:18 PM
xavx1's Avatar
i was told i need to reset the Transmision unit is that done with the Actron tool from autozone??
Old Feb 12, 2007 | 04:49 PM
wood_e's Avatar
ORIGINAL: david9999
Uh, you're kidding I hope... because that's completely incorrect.
not.so.hygh.lyfe.
Jan 31, 2015 08:01 PM
Clayson
Nov 29, 2013 07:34 AM
jmccracken0214
Jan 9, 2009 02:31 PM
fastlane
Jan 12, 2008 10:45 PM
