trottle position sensor??? eh?
Old Mar 19, 2005 | 12:48 AM
rnbguy's Avatar
Default trottle position sensor??? eh?
Hi,
I was getting a bad idle where the revs drop very low... so i followed instructions on vag-com which where as follows
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Measuring Blocks - 08]
Group 098 (Note: use Group 001 for ADY engine code)
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
[Switch to Meas. Blocks] button and you're all set.
But when i switched to basic settings it gave an error... now i get this fault code?
00670 - Throttle Position Sensor (G127)
27-10 - Implausible Signal - Intermittent
any tips people?
Old Mar 19, 2005 | 12:57 AM
Jestnomen's Avatar
6th Gear
Default RE: trottle position sensor??? eh?
did you try the adaption without a vagcom?
Old Mar 19, 2005 | 12:59 AM
rnbguy's Avatar
hows that done again????
thanx for ur reply btw
Old Mar 19, 2005 | 01:01 AM
Jestnomen's Avatar
6th Gear
turn the key and let it sit for at least 3 minutes. You should hear it clicking.
Old Mar 19, 2005 | 01:03 AM
rnbguy's Avatar
turn it to lights on position?
Old Mar 19, 2005 | 01:16 AM
Jestnomen's Avatar
6th Gear
The last click before you start the engine.
Old Oct 11, 2007 | 09:03 AM
justinclarke's Avatar
hi,
I'm getting the same issue here, as my battery has just died. My warm idle revs are around 550 and the car keeps feeling like its about to stall when i'm at traffic lights.
So i guess i need to do a throttle body alignment, i have a vag-com but just to clear things up, are you saying that by turning the key and letting it sit for at least 3 minutes will do the same job?
Cheers. Justin.
Old Oct 11, 2007 | 06:31 PM
can anyone confirm that?
i will try it tomorrow but it would be good to know if that will do the trick before hand.
Thanks.
Peterhopson84
Aug 20, 2013 09:57 PM
ayi
Nov 10, 2011 12:38 PM
cojo428
Aug 4, 2008 08:47 PM
shelbyturbo
Oct 2, 2007 12:07 AM
